location of fuses on the central board
#1 location of fuses on the central board
Is there anybody who can help me to fit the right fuse on the right place for my 63 XKE following the number of the following photo ?
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
It's obvious
By the way, I'm sure you're aware, but just in case...
...the fuse ratings on the plate are given in 'old money' blow rating i.e. the maximum current carried before the fuse blows. Modern fuses give the continuous rating which is usually about half the blow rating. So in position 1 you want a 17A fuse (= 35A blow rating), eg.
http://www.rimmerbros.co.uk/Item--i-GFS3035
More on the subject here...
viewtopic.php?t=3102&highlight=fuse+blow+rating
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
Thank's a lot Neil
