Wire wheel tyre replacement question
GravyGraham
#1 Wire wheel tyre replacement question
Post by GravyGraham » Tue May 19, 2015 6:01 pm
A naive question perhaps, but can I take my punctured wire wheel tyre to any regular tyre place to have it fixed? I just wondered if there was any fancy procedure or tools needed that your run-of-the-mill tyre place might not possess.
'72 Series 3 2+2, pale primrose/black
(plus miscellaneous Land Rovers!)
Post by Gfhug » Tue May 19, 2015 6:17 pm
The big thing appears to be that most modern fitters don't have the correct balancing equipment for wire wheels. The advice is to get one of these: http://www.smoothridecones.co.uk/ which allows a wire wheel to be properly balanced.
Maybe someone local can advise of a place geared up to do wire wheels?
Simon P
Post by Simon P » Tue May 19, 2015 7:17 pm
If you're in 'the wilds of Kent' you can't be far from E-type UK in Tonbridge: http://etypeuk.com/uk-car-sales/about-e-type-uk/
Either they ought to be able to do it or they must themselves use someone locally who they could recommend. Maybe give them a call?
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
1954Etype
Post by 1954Etype » Tue May 19, 2015 7:23 pm
The cones are also available from Fosseway performance.
Angus 67 FHC 1E33656
61 OTS 875047
steve3.8
#5 Re: Wire wheel tyre replacement question
Post by steve3.8 » Tue May 19, 2015 9:03 pm
Gravygraham wrote:A naive question perhaps, but can I take my punctured wire wheel tyre to any regular tyre place to have it fixed? I just wondered if there was any fancy procedure or tools needed that your run-of-the-mill tyre place might not possess.
A very valid question i think , but more important than balancing is whether the regular tyre fitter knows how to fit inner tubes correctly without straining the valve neck or nipping it between the bead and the rim , add caution ! .
Steve3.8
64 3.8 fhc, 67 4.2 fhc
Post by malcolm » Wed May 20, 2015 9:06 am
Am I right in thinking that replacement wire wheels can be either tubed or tubeless?
I saw some here:
https://www.google.co.uk/url?sa=t&rct=j ... yKhrXwpjZg
chrisvine
Post by chrisvine » Wed May 20, 2015 12:37 pm
The Dayton wheels do state they are tubeless. However when I discussed options with Dougal at Longstone Tyres he advised to still fit tubes. It might be worth giving him a call.
1969 S2 OTS, Elise S1
Post by Heuer » Wed May 20, 2015 12:43 pm
Although Longstone Tyres have a specially modified balancing machine for wire wheel, Dougal refuses to use it. Something to do with the way wires are constructed which throws the balancing machine into a hissy-fit. They use a bubble balance and afterwards, even at three figure speeds, there is no wobble in the steering. Personal experience having bought all my tyres from Longstone over the last 15 years.
Post by PeterCrespin » Wed May 20, 2015 1:22 pm
chrisvine wrote:The Dayton wheels do state they are tubeless. However when I discussed options with Dougal at Longstone Tyres he advised to still fit tubes.
The only logic I can see for that view is in case the Daytons have a slow leak, in which case exchange the faulty one at your retailer. This is not some home-made dab of silicone on the spoke head. If the tyre fitters use normal care there is no more likelihood of a leak than with a tube IMO - probably less.
If the wheels are damaged or spokes adjusted significantly then there's a chance of a leak but that's very rare. When's the last time you heard of wheels being rebuilt for any reason other than uber-originality? One of the Pepperpot alloys on my XJ12 had a slow leak, as does the front forged alloy wheel on my Triumph Sprint. Would Dougal suggest I run tubes in those?
Tubes are added unsprung mass and riskier than tubeless, which usually deflate very slowly. AFAIK it's not even proper to run tubes inside a cover not designed for them, due to fretting.
Post by mgcjag » Wed May 20, 2015 5:24 pm
Hi ALL....Been running on MWS tubeless wires for approx 4 years...with no tubes fitted....I opted for tubeless as the area i drive in is countryside with lots of hawthorn hedges, with thorns in the cutting season and as Peter said a puncture on a tubed wheel goes flat very quick....Dont understand why Dougal suggests using tubes on all wires....Pointless....Steve
dougal
#11 tubeless wire wheels
Post by dougal » Tue Aug 04, 2015 2:28 pm
This is a tubeless wire wheel that came to us yesterday. This is not the first time we have had problems with these wheels, the other common fault has been air coming out of the wheel round the spokes.
http://www.longstonetyres.co.uk/page/cl ... nner-tubes
Chain Gang for ever
dougal
Post by dougal » Tue Aug 04, 2015 4:30 pm
Ooops here is the film
Chain Gang for ever
Nick
Post by Nick » Tue Aug 04, 2015 9:52 pm
If it is a tubed tyre I doubt that the regular tyre fitters will keep tubes on their stock list. I recently had a puncture in a tubed tyre whilst up near Teeside and it was a bit of a hunt to find a new tube. A v.g. mobile tyre fitters replaced the tube for ?15, but they didn't try to rebalance the wheel. Provided the tyre position is marked in relation to the valve hole so that it is refitted in the same position with the new tube, the balance shouldn't be markedly affected.
Nick
1965 S1 FHC
Post by Heuer » Tue Aug 04, 2015 10:24 pm
I always carry a spare tube just in case.
Simon P
Post by Simon P » Wed Aug 05, 2015 7:45 am
Heuer wrote:I always carry a spare tube just in case.
I always carry a spare wheel, just in case....
:wink:
