Best Lightweight Starter for 4.2
Candellara
#1 Best Lightweight Starter for 4.2
Post by Candellara » Fri May 29, 2015 4:07 pm
My original starter motor has started to play up - namely not disengaging correctly
Any thoughts on lightweight starters and best place to buy?
69 4.2 FHC ex Race Car
F-Type V8S
Mercedes 300SL 107
iani
Post by iani » Fri May 29, 2015 4:21 pm
I got mine from Moss-Europe, you'd need to call them to make sure you get the right model for your car, ?158 IIRC and it works great.
Ian
Jaguar - 1970 S2 2+2 (sold), 1970 S2 FHC, X150 5.0 XKR, x250 XF x2 (sold) XF SportBrake
1968 Triumph GT6 Mk1
Post by Heuer » Fri May 29, 2015 4:23 pm
iani
Post by iani » Fri May 29, 2015 4:25 pm
Heuer wrote:Nippondenso: viewtopic.php?t=6668
That's an alternator David :D
Candellara
Post by Candellara » Fri May 29, 2015 4:49 pm
Two questions:
What are the variants for a S2 4.2?
Also, is this possible to change without removing carbs?
F-Type V8S
Mercedes 300SL 107
Post by mgcjag » Fri May 29, 2015 5:40 pm
Yes starter can be removed without removing carbs... Steve
Post by abowie » Fri May 29, 2015 11:01 pm
Candellara wrote:Two questions:
I think the starter is the same for all the 4.2 engines.
Some of the generic high torque starters have an adjustable mounting plate that can be rotated and locked in place. This is a nice feature so that you can get the angle of the starter right relative to the side of the block.
My series 1.5 has a nice hole with plate in the footwell that allows some access to the 2 bolts at the back of the starter. Not sure if this feature is there on series 2 cars but it will make getting the bottom bolt out a lot easier if it is. It's tight in there but you should manage with an appropriate amount of swearing and fiddling.
Replacing the 2 mounting bolts with hex headed screws has the advantage that you can lock the screw positively onto the tool which may make insertion easier.
