Rear Hub removal using the spinner
RogerM
#1 Rear Hub removal using the spinner
Post by RogerM » Fri Jun 26, 2015 4:49 pm
Is it possible / anyone tried removing the rear hub from the splined half shaft using the wire wheel spinner and a suitable spacer block? Is the centre of the spinner strong enough?
It seems to me that it would do the same job as the Churchill special tool shown in the manual.
I'm about to change the rear wheel bearings and looking to minimise the problems!
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
Post by mgcjag » Fri Jun 26, 2015 4:58 pm
Hi Roger.....took mine the CMC for them to remove, they had the correct tool....it still took a lot of effort with everv bit of the spline having to be forced out, they said that it was very common for them to be very tight.....another option would be to use a press, have seen on this forum recently someone usung a puller if i can find it will post here,...cant see the spinner getting anywhere neer it unless tney are loose.....Steve
Post by Gfhug » Sat Jun 27, 2015 8:06 am
I'll second what Steve says, mine hadn't been removed in a long time and had to give them to a local Jag workshop who needed all the correct heavy duty equipment to do the job.
Post by mgcjag » Sat Jun 27, 2015 8:25 am
Hi Roger...using a press...any workshop will have one. See this post page 12 viewtopic.php?t=6087&postdays=0&postorder=asc&start=110
#5 Re: Rear Hub removal using the spinner
Post by abowie » Sat Jun 27, 2015 9:00 am
RogerM wrote: and a suitable spacer block?
Roger
I reckon the idea has merit. Give it a go. Take photos and report back.
Moeregaard
Post by Moeregaard » Sat Jun 27, 2015 3:46 pm
I took the rear hub assemblies from my '65 to a local shop with a hydraulic press and they were still a bugger to get apart. As they say, "Don't try this at home."
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
RogerM
Post by RogerM » Tue Jun 30, 2015 9:08 am
Didn't need to try my idea as the hub fell off the half shaft BUT
whoever put the split pin in the castellated nut didn't want to get it out again, took me an hour moving it about 1mm at a time using some garden wire through the hub hole to maintain tension on the pin and long nose pliers. Then to undo the nut, in the end used a 4ft length of 1inch square steel tube I had lying around and it bent that slightly before the "crack" and freedom.
Only got to push the hub off the carrier now; bearings are totally shot!
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
David Oslo
Norway
Post by David Oslo » Tue Jun 30, 2015 10:45 am
I have previously struggled on old cars & nuts with extensions bars and long tubes, until I bought a impact wrench. Have used them for years at work but never made the 'connection' to invest at home. Now even the most resilient "4 foot extension" nut cracks off in a few seconds. Just make sure to use the proper black impact sockets.
David
S2 OTS '70 (arriving)
Post by abowie » Wed Jul 01, 2015 12:04 am
RogerM wrote:Didn't need to try my idea as the hub fell off the half shaft Roger
Excellent; that's how it should be. When you reassemble them use plenty of "Never Seize" on the splines. If the rust or some genius has Locktited them in place they can be a proper bastard to get out, even with a big press and oxy.
JagWaugh
Switzerland
#10
Post by JagWaugh » Wed Jul 01, 2015 4:49 am
Yep, second that on the nevr sieze/coppaslip. I think the idea of the loctite was to eliminate microfretting, it certainly wasn't to hold things together during Operation, otherwise there wouldn't be a whacking great nut torqued to such a hich value on the end of the yoke.
It is quite easy to tell if yours are loctited together... they will only come apart with the correct puller or a press. If you try the knockoff method start with just one. If you break the knockoff it is NOT a sign that the knockoff had a flaw, it is a sign that yours are loctited: you need a puller or a press.
Quattrofrank
Norway
#11
Post by Quattrofrank » Wed Jul 01, 2015 6:59 am
Mine was locktited together and even with the hub puller tool I was struggling. Ended up bending the press screw on the hub puller tool.
I never seen locktite be used like this before and didnt used it when reassembling. With splines and a nut torqued to 193nm it shouldnt be a problem.
dal2.0litrefrogeye
Post by dal2.0litrefrogeye » Tue Jul 14, 2015 5:13 pm
Hi I would be very supprised , and you would be one lucky guy to knock them apart , when I took mine apart with our new 30 ton press at work , the press didn't struggle , but the interference fit was there all the way to the last mm of spline , all so the thought of wealding a hammer in the close proximity of wheel arch , splines on hub , or worse your jaw / nose / teeth , or all of the above , and getting your swing a "little" wrong !!! Sure makes the extra hassle of stripping hub and drive shafts off car worth while
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
mikey1
#13 hub removal using spinner
Post by mikey1 » Wed Sep 23, 2015 3:41 pm
It can be done but I only mention it in case someone has no access to a press. many years ago, when I was young, impecunious and, perhaps foolish, I did succeed using this method. It took me two days and the splines clung on to the last quarter of an inch. Definitely not to be recommended.
Mike Williamson.
Mike Williamson, series 2 ots,
#14 Re: hub removal using spinner
Post by PeterCrespin » Wed Sep 23, 2015 6:06 pm
mikey1 wrote: when I was young, impecunious and, perhaps foolish, I did succeed using this method.
I tried being impecunious but ran out of money.
trondvo
Norway
#15
Post by trondvo » Wed Sep 23, 2015 6:20 pm
I used the "shop press" method when taking apart the rear hubs.
http://www.thegaragegazette.com/index.php?topic=383.0
The 20T shop press was really put to test, dont think they would have come off by hand tools alone.
61 OTS Black on Red, 62 FHC nuts & bolts resto on the way to OSG & Matador red.
David Oslo
Norway
#16 Re: hub removal using spinner
Post by David Oslo » Sat Sep 26, 2015 10:18 am
mikey1 wrote: many years ago, when I was young, impecunious and, perhaps foolish, I did succeed using this method.
Mike Williamson.
Now that's an oxymoron if I ever saw one .... a young, impecunious E-type owner
Unless of course the E was the root cause, that would explain it!
David
mikey1
#17 Rear hub removal using the spinner
Post by mikey1 » Fri Oct 02, 2015 11:25 am
Correct - I wasn't impecunious before I bought the E-type, ?2400 in 1977. I didn't know what I was doing and the car was a disaster. Still got it , though.
Mike Williamson.
