electrical bonnet plug
Polse7317
#1 electrical bonnet plug
Post by Polse7317 » Fri Jul 17, 2015 11:38 am
Hi guys, is there a rule for connecting the different wires on the bonnet plug ? the wire in the middle is the horn one y think. May be is an rule for the others ?
Post by Heuer » Fri Jul 17, 2015 12:00 pm
There certainly is. Follow the numbering in the Jaguar wiring diagram. The bonnet plug terminal numbers are those in the circles:
Use this diagram from the Forum Knowledge Base: https://dl.dropboxusercontent.com/u/627 ... %20ACD.bmp
Alty Ian
Post by Alty Ian » Fri Jul 17, 2015 12:17 pm
I did my bonnet plugs last night :)
Dont forget to follow the numbers on the plugs as they are handed.
Number 6 is for a fog light (optional) so I just left the blank plug in to help the plugs grip each other. :?
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
osgii
Switzerland
Post by osgii » Fri Jul 17, 2015 1:23 pm
Good luck... I messed everything while welding the wires to the socket (got the original one with the wood slices).
1E35547
Polse7317
Post by Polse7317 » Fri Jul 17, 2015 2:38 pm
On the diagram, I see the number 2:(headlamp high), 3: (headlamp low) 5: (side lamp) , 7: flasher right , 8 flasher left I don't see the 6 which is for the fog light that y havn't (thanks Ian) I think that the 1 is for the Horn ( center) but I don't see the "4" !
Another remark is that I keep the original plug apart , not on the car , because I am afraid with connecting problems with this old electric part, but may be Am I wrong and it would be better to fix the original one.... ?
Post by Heuer » Fri Jul 17, 2015 2:50 pm
1 = Earth
2 = High Beam
3 = Low Beam
4 = Horns
5 = Side lights
6 = Fog lights (optional)
7 = R.H. Flasher
8 = L.H. Flasher
Polse7317
Post by Polse7317 » Fri Jul 17, 2015 3:04 pm
Thanks Heuer
andrewh
Post by andrewh » Sun Jul 19, 2015 6:34 am
If you propose changing the plug you will need to buy a matching female socket as the repro plug I bought did not correspond / match each other. Just be aware of this possibility
1962 3.8 Series One FHC
