Hi. Does anybody know where I can obtain a tool for locking the flywheel while refitting flywheel and clutch etc?
OR: are there any suggestions/ideas how to hold the flywheel in position while tightening up the bolts?
Many thanks for any help available.
Kind regards,
George
4.2 Flywheel Locking tool
If I need to lock the crankshaft I use a right angled piece of angle iron - one say 2" X 3" is amply big enough - which I bolt through one of the backplate holes and engage on the flywheel. If , however, you are refitting the flywheel, then there is no need initially to lock it against rotation - a single bolt serves to stop it rotating and then you do the others up in sequence. Then use the angle iron to stop it rotating whilst you apply final torque
#3 Re: 4.2 Flywheel Locking tool
The fasteners for clutch or flywheel attachment are not so big that any harm will come of just putting a socket on the damper nut at the front to hold the crank. Presumably your engine's not on a stand, so I do it resting a socket and tommy bar, or my special big ring spanner, on the deck at the front.gmunro wrote: are there any suggestions/ideas how to hold the flywheel in position while tightening up the bolts
