What is this?
Pim
Netherlands
#1 What is this?
Post by Pim » Thu Sep 17, 2015 6:37 pm
Can anyone tell me what this is?
I was checking how to remove the pipes behind the bulkhead and there it was, some kind of cable with a spring and a fixture. Seems to come out thenother side of the bulkhead in the engine compartment.
Pim van der Schaaf
1E34261
1A33630BW
Alty Ian
Post by Alty Ian » Thu Sep 17, 2015 7:16 pm
Its the wiper parking position adjuster. It connects to the wiper rack.
Coincidentally, I just adjusted mine when getting the wipers going, I needed to use it to get the wiper parking switch to work correctly. Check your wiper rack and you will see where it connects.
Pim
Netherlands
Post by Pim » Thu Sep 17, 2015 8:27 pm
Thanks Ian, I will have a second look at it. See if I get it.
Pim van der Schaaf
1E34261
1A33630BW
Post by PeterCrespin » Sat Sep 19, 2015 12:02 am
It's a courtesy light switch from where I'm looking. It IS only a small iPhone screen though...
Moeregaard
Post by Moeregaard » Sat Sep 19, 2015 3:37 am
Parking adjuster for the windscreen wipers. The small knurled knob at the other end of the cable protrudes from the firewall on the left side.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Post by PeterCrespin » Sat Sep 19, 2015 10:16 am
Ah, right, the inboard wiper rack end. I was looking for the knurled knob - duh.
Pim
Netherlands
Post by Pim » Sat Sep 19, 2015 8:30 pm
Moeregaard wrote:Parking adjuster for the windscreen wipers. The small knurled knob at the other end of the cable protrudes from the firewall on the left side.
That is indeed where it goes, with a kind of flat hex nut on the outside of the bulkhead.
Pim van der Schaaf
1E34261
1A33630BW
Polse7317
Post by Polse7317 » Sun Sep 20, 2015 7:45 am
That's it :
Pim
Netherlands
#9
Post by Pim » Mon Oct 19, 2015 5:23 pm
Thanks, looks different than mine. PO painted over it.
Pim van der Schaaf
1E34261
1A33630BW
vee eight
Post by vee eight » Mon Oct 19, 2015 6:12 pm
Out of interest, how do you adjust the position.
Is it from the knob on the bulkhead or from the cable inside the dashboard.
1967 Series 1 E Type Roadster - 1968 TR5 - 1966 Corvette Stingray Convertible
Alty Ian
Post by Alty Ian » Mon Oct 19, 2015 6:34 pm
vee eight wrote:Out of interest, how do you adjust the position.
By turning the knurled knob you move the arms relative to one another and compress or decompress the spring over the thread which keeps it under tension.
Pim
Netherlands
#12
Post by Pim » Tue Oct 20, 2015 9:18 am
By turning the knurled knob (located on the bulkhead, right side of the picture - PvdS) you move the arms relative to one another and compress or decompress the spring over the thread (in the dashboard, left side of the picture - PvdS) which keeps it under tension.
Pim van der Schaaf
1E34261
1A33630BW
