PB of electric connection
Polse7317
#1 PB of electric connection
Post by Polse7317 » Wed Sep 30, 2015 12:38 pm
I am connecting all the wires on my new harness and I don't see the stop switch on the pedal box is it here or in another place ?
My second question is about the wires for the reverse lamp. I have the wire arriving from the rear lamp on the left side wich is ok when I test it but I have no wire from the connecting plug to the switch on the gear box....! I don't find any couple of wires going to the gearbox if some one has pictures of the wires so I can see where they come from..... it would be very helpfull ....
ALAN COCHRANE
Post by ALAN COCHRANE » Wed Sep 30, 2015 1:01 pm
Yves
Do you mean the mechanical stop switch usually found on the brake pedal shaft?
Series 1 3.8 cars didn't have one. The brake lights are operated by an Otter Switch which is situated under the bonnet, This is plumbed into the brake line. From memory it's mounted on the picture frame, in front of the engine block on the inlet (carb)side. At least it is on a Right Hand Drive car. It maybe on the opposite side in your car if it's LHD.
I'm sure someone else can clarify this last point.
Alan
Alan Cochrane
Polse7317
Post by Polse7317 » Wed Sep 30, 2015 4:38 pm
of course y're right :oops: y din't remember that part effectively fixed on the front frame (shame on me)
Post by Gfhug » Wed Sep 30, 2015 5:02 pm
Yves, here is an upgrade for the brake light switch you might wish to try:
viewtopic.php?t=3134
