Post
by MarekH » Wed Sep 23, 2015 1:27 pm
I'd guess at opalescent golden sand.
The photographer should be shot:-
Firstly, by moving just an inch to the left, the upright of the ferris wheel could be made not to come out of the guy's head.
Secondly, the bicycle should be removed, either physically or by photoshop.
Thirdly, (s)he should have used a remote shutter cord and stepped back three feet - what an embarassing and obvious shadow to leave on the foreground.
Next, the camera is not level. Look at the perspective of the concrete blocks and you'll see that the camera points downwards. This can eaily be fixed by either using a perspective shift lens or by altering in photoshop again if it is digital. This would also help not make the guy's legs look four feet long which the incorrect use of wide angle lens has exacerbated.
The wide angle lens has the wrong lens hood on it - look at top two corners where it darkens the edges because it is in shot.
Lastly, if you want to photoshop a bit of sky into the middle, a more saturated colour blue wouldn't go amiss. Clearly not photoshopped - at least not by anyone with eyesight better than Stevie Wonder.
