Dear all,
Should the chrome headlight surround fit over the bonnet fastening strip, if so it leaves a significant gap, or should the fastening strip butt with the chrome surround, which would eliminate the gap.
Thanks in advance,
Guy
Bonnet fastening strip meets headlight chrome
guyjohnwood@aol.com
Topic author - Posts: 27
ALAN COCHRANE
Hi Guy
My bonnet strips fit under the crown ring. I think this is generally the set-up. I bedded the seal in with grey sealer to counter the slight lifting that.occurs.
Forget about trying to stop leaks into the sugar scoops. The seal's real job is to stop the crown ring scratching the paintwork.
I also injected sealer in the gap between the wing and bonnet top where it is covered by the crown ring. This is where. most of the leaking seems to occur.
Hope this helps.
Alan
Hope this helps.
Alan
Alan Cochrane
The factory scooped out the end of the strip so it followed the curvature of the chrome ring and then butted it up. It didn't go under the ring.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
