Front indicator sidelight lenses
#1 Front indicator sidelight lenses
Post by Gfhug » Tue Nov 03, 2015 11:58 am
Is there a reason for the lower half of the front sidelight and indicator lenses to be opaque?
It is as though a silver or grey paint has been applied. Not as a later overspray but during manufacture. Symbols on the lenses are Lucas, E11, 7126, 6121. Are these correct for a Series 2?
Maybe Marek can say if his reproduction ones are like that?
MarekH
Post by MarekH » Tue Nov 03, 2015 3:22 pm
Dear Geoff,
Yes some were supplied with one half blanked off by painting the bottom silver/grey on the inside, but I've only seen this on one side. I have no idea what the purpose was but can only speculate that there may have been some minimum height requirement for indicators in some markets or some other such reason not to glare oncoming traffic. It is correct for the s2, but I don't know for which market that would apply.
I can make these any way you like. One person approached me for a set with clear bits painted orange and the orange bits made clear as he wanted large LED daytime running lights on his car.
Post by Heuer » Tue Nov 03, 2015 4:21 pm
Post by Gfhug » Tue Nov 03, 2015 4:36 pm
Thank you, David. Now to get a gold star instead of just 10/10 can you tell me why the lower half was obscured? :wink:
Perhaps as Marek suggests it was something to do with legal height of lights in the UK. Will I get told off if I get Marek to supply unobscured lenses?
Post by Heuer » Tue Nov 03, 2015 5:31 pm
No idea. It could be some regulatory thing which was expected but subsequently failed to materialise because they stopped doing it after 1R1765/IR20922/IR35932. I would recommend using the un-blanked version to make your intentions as clear as possible to others.
MarekH
Post by MarekH » Tue Nov 03, 2015 5:45 pm
The XJ12 also used the same front indicators, so maybe these were unobscured ones. Given that they sit underneath the chromed front bumpers on the etype, maybe the light pattern is somehow improved by reflection caused by the grey paint?
The s3 has ordinary all orange lenses and the sidelight function is moved to the sealed beam headlight.
Simon P
Post by Simon P » Wed Nov 04, 2015 9:34 am
Heuer wrote:No idea. It could be some regulatory thing which was expected but subsequently failed to materialise because they stopped doing it after 1R1765/IR20922/IR35932. I would recommend using the un-blanked version to make your intentions as clear as possible to others.
'Ere - you can't go around insisting on exactitude in all things Series 1, and then adopt an 'any old thing will do' approach to Series 2s!
Fit semi-obscured on UK-supplied cars up to 1R1765/IR20922/IR35932: fit clear otherwise.
Thank you.
:D
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
Bernie2015
Post by Bernie2015 » Tue Dec 08, 2015 9:17 am
Do you happen to know if there are any restrictions on indicator lenses on a series 2 to get it through an MOT. I am about to buy a pair of completely orange ones for the front !
Post by Gfhug » Tue Dec 08, 2015 12:38 pm
Is your plan to change the sidelights into part of the indicators? Or to do as I have and change the semi obscure white/orange into clear white/orange?
As such I'm not sure of requirements for sidelights, but as Marek points out they are in the headlights on the S3, so fit those to solve the question of having sidelights. Then you would have full orange side/indicators as indicators only as per the S3. If the S3 can be like that why can't the S2?
If changing your headlights to include sidelights then also consider getting the Philips xtreme H4 or H7 bulbs for brighter mains. There's a thread eslewhere about them.
Bernie2015
Post by Bernie2015 » Thu Dec 10, 2015 11:48 am
Thanks that's realy helpful. Does that mean the electrics have to be changed so that sidelights are in the main headlights?
Post by Heuer » Thu Dec 10, 2015 11:51 am
Yes. You can't have amber side lights showing at the front (MOT failure) so you need to go with amber/clear or amber/headlamp sidelights.
iani
Post by iani » Thu Dec 10, 2015 1:03 pm
Or go with clear lenses and have an amber turn indicator bulb, no problems with MOT then.
E-type - TBC
1968 Triumph GT6 Mk1
