Tyres for winter
mark10337
Switzerland
#1 Tyres for winter
Post by mark10337 » Sun Nov 22, 2015 1:57 pm
Has anyone found a manufacturer for correct sized winter tyres (185VR15) for the eType? I'm in need of some winter boots!
-Mark
Post by Heuer » Sun Nov 22, 2015 2:33 pm
Lots of choice in 185/65 R15 if you can get away with the lower profile (65 vs 80) and ride height: http://tinyurl.com/onan96q
pmansson
Sweden
#3 I never drive on wet, salty roads in winter
Post by pmansson » Thu Dec 03, 2015 11:24 pm
To exercise the cars on dry winter roads is ok, but be very careful if the roads have had salt on them and are wet from either rain or melted snow. The front and rear axle will have surface rust on all the nuts and bolts, most of the black painted parts when you inspect it on a lift in spring. Wetting the underside and then putting the car back in a heated garage is a recepy for disaster if your front and rear axle have been rebuilt. I have deliberately left body rust out in this argument.
With these rules, my cars don?t need winter tyres, but everybody should use their cars the way they want.
mark10337
Switzerland
Post by mark10337 » Fri Dec 04, 2015 9:56 am
Most posts seem to look at the 185 or 205 sized tyres. Are the 195 also a possibility for a middle ground. Seems to be a good choice of 195/70/15
-Mark
mark10337
Switzerland
Post by mark10337 » Fri Feb 12, 2016 9:46 pm
Just to update for the record, I ended up using Continental Winter Contact 205/15/70.
I'd considered some of the 195 sizes, but they were for commercial vehicles (denoted by a C on the type). These would give a much harder ride as they are designed for a heavier load, e.g. from vans etc. and would not have given a good ride experience.
So far, the Continental's have performed fine. A rear wheel drive car is not the best choice in snow for a start, but, besides the better grip at temperatures below 7C - these have performed adequately in fresh snow also.
-Mark
Moeregaard
Post by Moeregaard » Sat Feb 13, 2016 1:33 pm
If I lived in a snowy climate where road salt was used, whatever choice of tire I chose would be installed my disposable car, while the E-Type hibernated in its heated garage.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
