GPS trackers
#1 GPS trackers
I know this has been discussed before but time has passed and newer options are available.
Just wondered if anyone can recommend any?
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
a few warnings on my side:
1/ they do consume significant energy => without battery charger, they will empty your battery in 3 weeks
2/ thieves can find how to foul GPS on eBay for 100?
3/ if the car is inside a truck/lorry or a building , you loose GPS signal...
4/ you need a SIM card, of course, no communication is free in this world (and I wonder nobody asked to pay for GPS satellites signal...)
apart from that the one I bought on ebay from HongKong did work OK, once you managed to understand the chinese to english translation...
for that reason and point N?1 I would not recommend it, however, and by te way I disconnected it long time ago; a metal bar joining steering wheell and pedal is more reliable, IMHO
2+2 1970
#3 GPS tracker
I had a chip n track fitted to my car. Without it I would not have the car. SCUM sawed through the steering wheel, loaded it onto a flatbed and took it to Essex. Chip n track worked and the police recovered my car in 12 hours. They did look for a tracker but did not find it. Best ?120 I ever spent.....other than buying the car of course.
Steering lock in a series 1 is virtually pointless as a hack saw will chop the wheel in three mins. Now I have ram raid posts, a shroud lock that encloses the wheel, alarm system and the tracker. Suggest you all do the same. J
Removable steering wheel works for me: viewtopic.php?t=1339&postdays=0&postorder=asc&start=0
CMC have stopped supplying them but apparently they are available from: JWA Components http://www.jwaracing.com/ 01785 851122 at ?300.
Hi Ian...have a look at this.....havnt used one myself but it has good reviews in the Mercedes club gazett... http://www.pakatak.co.uk/shopv7/product.asp?P_ID=649 this is a totaly wireless unit and has its own internal rechargable battery
PS...a fuel cutoff switch works well, but only if you havnt told everyone where youve hidden it
My car has a natural fuel cutoff these days
Interesting idea this bonding tracker.
How do you detach it from steel however when you need to recharge it?
Serge
1964 (3.8) FHC
1961 OTS
1964 (3.8) FHC
1961 OTS
Pull it off its magnetic
#8 Re: GPS tracker
cactusman wrote:I had a chip n track fitted to my car.
do you mean
http://www.chipandtrace.com/#home ?
do you mean they could not find where your tracker was hidden in the car ?cactusman wrote: They did look for a tracker but did not find it.
It still does not bring a solution if the car is indoors or in a Metal Lorry or if the thieves have a GPS signal blurrer (ie if they are professionals)
but yes, it will fool the apprentice, and there are a quite a few wandering around
2+2 1970
#9 Tracker
They looked. They failed. And no point asking me where it is either I am afraid. Won't work in a shipping container but works fine in an Essex car thiefs barn.
Mine was not chip and trace. Just a basic GPS device with a sim. Company is/was? Chip n Track. Any number out there. And yes you can pay more and get one that does work in a shipping container or so they claim. Or you can put it in the garage, chain it to the floor with a huge shroud over the wheel, alarm the garage and then put ram raid posts behind the door like I did. J
