lightweight wheel look
#1 lightweight wheel look
i have a series 1 2+2 1967 4.2 and want to change from wire wheels to steels back is ok using s type hubs ,but what can i do to front to adapt spline to stud hubs help needed thaks
Frenchi , the series 1 E-type stub axle carrier is the same as Mk 2 - so you just need to fit the parts you need from the Mk 2 range - the steering arm is E-type only though.
Barrie
Barrie
