I cannot find details or pictures of how the headlights are attached to the bonnet panel. My car was dismantled by a previous owner and some parts are missing.
Ideally an exploded diagram is required to identify the different parts and the order of assembly.
Fitting headlights to S1 bonnet
The pictures in the Barratt's calalogue are quite good.
The bowl screws to the bonnet with self tappers, with the seal in between.
#3 Series 1 headlights
Pretty certain my back outer bowls are held on with small bolts and captive nuts on the panel behind. The chrome retaining ring that actually holds the lamp in place is screwed to the inner bowl by self tappers. The inner bowl is held to the outer by a spring.
Getting the scoop in place is a bit of a fiddle! That goes in before the bowl!
#4 Head light bowles
Please see my post from sunday Aug 30 in technical about the bolts that fit the headlight bowles hope this helps
Clive
Clive
richard btype
#5 Re: Head light bowles
I believe I read that thread last evening - very informative it was too...154WHU wrote:Please see my post from sunday Aug 30 in technical about the bolts that fit the headlight bowles hope this helps
Clive
3.8 FHC Chassis no: 860403
DOM - 11th April 1962
Also
4.2 FHC Chassis no: 1E32173
DOM - 12th December 1965
Also
