Switch Panel Removal
colinevans
#1 Switch Panel Removal
Post by colinevans » Sat Jan 30, 2016 7:00 pm
Hi guys, trying to replace the headlamp switch. Can anyone advise how to remove the radio console to get to the switch panel properly? Hinging the switch panel down and removing the actual switch panel screws still don't give enough room to access and push out the switch as the trim on top of the console fouls it. Thanks for any advise, must get round to buying a manual!
Colin
Series 2 OTS, 280SL
Moeregaard
Post by Moeregaard » Sun Jan 31, 2016 12:00 am
You've discovered the No. 1 cause of broken switch indicator strips!
There are two thumbscrews on either side of the radio console. Remove these and carefully bend the sides of the console outwards to clear the studs. With the shift lever in 2nd or 4th, slowly work the console back and over the shift lever. This can be a bit of a bugger if the carpet padding in this area is thicker than it should be, but patience and perseverance will win here.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
andrewh
Post by andrewh » Sun Jan 31, 2016 8:42 am
Mark, I sent you a PM that you perhaps have not seen. thx Andrew
1962 3.8 Series One FHC
cactusman
#4 Central console
Post by cactusman » Sun Jan 31, 2016 8:48 am
Wise words from Mark. I thought mine was the only car you had to remove the thumb screws from to hinge the panel out!!! I assumed i had something misaligned.....it was on the to do list. May as well remove it from the list as it seems it is a common trait then. I learn something every week on here...brilliant.
colinevans
Post by colinevans » Sun Jan 31, 2016 5:18 pm
Thanks Mark and Andrew
Safely removed! Now to figure out which wires go back where as about 8 spades pinged off when I released the panel! Happy days.
Colin
Series 2 OTS, 280SL
cactusman
#6 Switch panel removal
Post by cactusman » Sun Jan 31, 2016 8:24 pm
Ah yes...I should have mentioned that. I usually have the one to the voltage regulator and the starter solenoid fall off! Bet you will have different ones though.
