This design meant the by-pass 'slot' is open when the thermostat is closed. The coolant remains within the engine to shorten warming-up time. When the thermostat commences to open the screen moves upwards (to the right on the photo below) and gradually shuts the by-pass. Coolant now flows from the engine to the radiator only.
However these alcohol filled bellows thermostats were not suitable for use above 4psi so when the coolant pressure was changed to 9psi after cars #879043/850656/861090/888240 they used the Waxstat type #C20766/2.
The disc you refer to does nothing on the 3.8 manifold as it is too small and designed to block a by-pass hole immediately below it.
The dual poppet thermostat was used on the S1.5 and S2 cars and will be useless on the S1 manifold:
If you fit the wrong one on the S1 manifold this is what you ger:
