I'm just replacing my standard needles with UE needles (due to change of filter). Please does anyone know how far into the piston I should seat the needle. There's a groove in the needle but I'm not sure if thhis is a depth marker or groove for the clamping screw. Any advice would be much appreciated.
SU Needle Replacement Help
Hi Neil...have a look here...all you need to know about SUs http://sucarb.co.uk/technical-carburett ... ettings-hs
There are also several guides in the Forum KB on setting and maintaing SU's.
Thanks both. Believe it or not I searched for needle replacement on both the SUCarbs site & this forum without success. Needles now correctly installed.
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
