indicator stalk
265bhp
#1 indicator stalk
Post by 265bhp » Sun Mar 20, 2016 5:52 pm
hi
the end of my replacement indicator stalk from Richard Smith that I bought some time ago has a fluted profile, yet when I came to try and fit it (original lost before I bought the car) i can see the original had a threaded end...?
is this an early car anomaly or did a previous owner tap a thread perhaps..?
I could try and thread the end of the new stalk, but the chrome plating will make this difficult, and I don't know what thread is (not 2BA or 3/16 UNF as i tried a spare bolt)...so should I drill out and go for a push fit...?...is that what the later cars had perhaps..?
thanks
Jonathan
1954Etype
Post by 1954Etype » Sun Mar 20, 2016 9:10 pm
Not threaded, splined as in the one you have.
Angus 67 FHC 1E33656
61 OTS 875047
265bhp
Post by 265bhp » Sun Mar 20, 2016 9:50 pm
Thanks Angus
Good to know what I should have, but something isn't right then...the Lucas part has a date of 2-63 which would tally with the car which is a March build, but the depth of the threaded hole is only 6mm or so, and then splines are more like 12 or 13. So they will not get enough purchase...if I drill it deeper I am getting close to the pivot point on the indicator pivot...and why should I be modifying a part if it is the original part...Ethan's that is the issue...?...does the black coloured indicator pivot which receives the stalk look correct to you please ?
Jonathan
Post by mgcjag » Sun Mar 20, 2016 10:06 pm
Hi Jonathan...try a search here for indicatos stalk...there are a few posts.. this one may help
viewtopic.php?t=6495&highlight=indicator+stalk
265bhp
Post by 265bhp » Sun Mar 20, 2016 11:20 pm
Thanks Steve
Good to read through....Interesting point about the lack of knurled ends as the stalks on Richards stand today at Stoneleigh didn't have them
The bit that doesn't make sense is why mine has a threaded hole....as I clearly recall unscrewing a short remnant bit ....I can only conclude mine has been changed in the past...looks like I need a replacement pivot piece..or modify mine to increase the depth
Jonathan
Post by PeterCrespin » Mon Mar 21, 2016 12:48 am
Your stalk receiver bit looks manky. Threads are home-made.Is it epoxy or goo around the hole? It should be press fit into the mazak quadrant IIRC. Doubtless it's all done on a jig originally. I'd epoxy it in and build up around the insertion.
neil4444
Post by neil4444 » Mon Mar 21, 2016 6:32 am
Hi Jonathan,
Also a thread doesn't make sense as how could you initiailly tighten it to get it in the correct position, plus every time you indicate it would tighten or loosen.
Neil
1962 S1 OTS
1967 S1 FHC
Simonpfhc
Post by Simonpfhc » Mon Mar 21, 2016 7:04 am
Jonathan,
That 'threaded joint' doesn't look original, or at least compared to mine. Mine has a long (5-8mm maybe) sleeve protruding where you seem to have a diy brazed thingy.
I will try and get a picture later today.
Cheers.
62 3.8 FHC
91 Porsche 928GT
#9 Re: indicator stalk
Post by abowie » Mon Mar 21, 2016 7:23 am
265bhp wrote:hi
Someone's modified that. There should be a cylindrical piece about 1/2" long there with a splined hole in it.
265bhp
Post by 265bhp » Mon Mar 21, 2016 9:25 am
Thanks guys, that all makes a lot of sense, especially the bit about a thread unwinding when using the indicator....
Simon, a picture would be excellent to have, then I can see what I need to replicate....although I will also see if a replacement part can be bought, will put up a wanted add
Jonathan
neil4444
Post by neil4444 » Mon Mar 21, 2016 9:43 am
I had to purchase a complete repro unit as the entire assembly & housing was missing from my 3.8. Can't remember if it was from Holden or SNG but look the same. Pic here...
http://www.holden.co.uk/displayproduct. ... allery]/0/
Neil
1962 S1 OTS
1967 S1 FHC
nefematic
Post by nefematic » Mon Mar 21, 2016 2:04 pm
Jonathan,
before (again) changing or even renewing the main part, you could have a part made which has a thread for the existing thread, and the female part sticking out to receive the indicator handle. You might have to shorten the indicator handle to keep the overall length in check. I think that wouldn't look too bad?
Martin
Martin Scherz
Late S2 1970 OTS US LHD
Simonpfhc
Post by Simonpfhc » Mon Mar 21, 2016 6:40 pm
Here's a picture of mine when I rebuilt it:
If you end up buying a complete unit, I will buy the new shaft off you.
Cheers.
62 3.8 FHC
91 Porsche 928GT
265bhp
Post by 265bhp » Mon Mar 21, 2016 9:27 pm
Hi Martin...kind of what was going through my mind today.......or I see if I come across the female part in some auto jumble and swop it over...or modify a female part and piggy back it on....it's the splines that would probably be the tricky part to replicate..we have plenty of 3D printers at work..but sadly none of them print in metal...🤔
Simon..sounds like a plan if all else fails..!...thanks..😉
