TrevS
Post
by TrevS » Fri Apr 01, 2016 9:37 am
Hi there
I am looking to freshen up my headlamps and the scoops behind the glass covers look a little bit grubby etc. I've got 2 options, get my local bodyshop to paint them or buy a new set.
Can someone tell me if I buy a new set will they need painting or should they just be inserted as they come? Also is there any trimming etc required to get them to fit? Looking to get them from SNG Barratt
Trevor
- Trev S -
ALAN COCHRANE
Post
by ALAN COCHRANE » Fri Apr 01, 2016 10:25 am
Trevor
Repair rather than replace. With cars like ours it's important to retain as much of the OE as possible. You don't want to end up with a replica
Alan
Alan Cochrane
Pim
Post
by Pim » Fri Apr 01, 2016 12:39 pm
Should you decide to buy new from SNGB, they come painted (hammertone finish) ready to install.
Pim van der Schaaf
1E34261
1A33630BW
Post
by christopher storey » Fri Apr 01, 2016 12:57 pm
A quick wire brush down, and a can of steel wheels, and you're away for another 50 years !
- Administrator
Post
by Heuer » Fri Apr 01, 2016 1:06 pm
And you know they will fit!
Post
by abowie » Fri Apr 01, 2016 10:40 pm
Heuer wrote:And you know they will fit!
Which is by far the most important consideration.
There is a rubber U section strip that goes all the way around the front of the scoop. This is best glued in place with Superglue prior to fitting.
Pay attention to the positioning of spacers etc on the 3 bolts when you remove them.
- Administrator
Post
by Heuer » Fri Apr 01, 2016 10:52 pm
And despite what you may think the bolts are attached to the captive nuts on the scoop and then pass through the diaphragm. Nuts are fitted on the wheel well side.
mylesw
Post
by mylesw » Sat Apr 02, 2016 5:35 am
I have the same dilemma as Trevor and would prefer to keep the originals despite one of the captive nuts having rusted away. What colour paint do I need to buy and who makes it?
Myles
1964 RHD 3.8 FHC
Quattrofrank
Post
by Quattrofrank » Sat Apr 02, 2016 6:12 am
I used hammerite grey or was it hammerite silver.
Fixed Head
Post
by Fixed Head » Sat Apr 02, 2016 6:29 am
Originally they were a straight silver-grey metallic, NOT hammertone, unless it's a flat-floor car in which case they are body colour.
Post
by christopher storey » Sat Apr 02, 2016 7:05 am
As I said in my earlier post, I find a paint called Steel Wheels as close as one can get to the original, and it is very convenient to use, needing no primer
ALAN COCHRANE
Post
by ALAN COCHRANE » Sat Apr 02, 2016 9:58 am
Flat floor E-Types also had silver painted sugar scoops as well. Certainly all the ones I've seen including my own.
Alan
Alan Cochrane
- Administrator
Post
by Heuer » Sat Apr 02, 2016 10:21 am
Only the very early S1 cars (first 500) had body painted scoops. It was changed after complaints about the headlights and Jaguar thought this would improve things. In actual fact I found out, 54 years later, that the addition of a couple of simple relays solved the problem!
Fixed Head
Post
by Fixed Head » Sat Apr 02, 2016 1:00 pm
Alan and David, this is one of the very early features that did not change after just 500 cars. Body-coloured sugar scoops roughly coincide with the 'welded-louver' bonnets, which continued through at least most of the run of flat-floor cars. Whether or not Jaguar had complaints about the lighting, there are also other differences in paint finishes that would indicate that these earlier bonnets were painted in a more fully assembled state. --Mark
Pim
Post
by Pim » Sun Apr 03, 2016 10:09 am
I'll check with the original. I have one lft with the car, the other one got lost with one of the POs apparently.
Pim van der Schaaf
1E34261
1A33630BW
