Triple HD8 rebuild
Vegard
Norway
#1 Triple HD8 rebuild
Post by Vegard » Fri Apr 15, 2016 9:24 am
As some of you know, I'm in the process of removing the Stranglebergs and fitting a set of HD8s on my dad's E-type. I'm also rebuilding the carbs, and fitting a cable conversion kit. I've got a couple of questions in that matter.
What are the items marked out here??
Someone mentioned that some holes needed blanking when going from twin Strombergs, which are these??
68 1.5 FHC, 65 4.2 FHC, 72 MGB GT, 6 Minis, 71 Escort1300GT, 65 BMW Neue Klasse, 62 Volvo P1800 and a 205 GTI
#2 Re: Triple HD8 rebuild
Post by abowie » Fri Apr 15, 2016 10:13 am
http://sucarb.co.uk/carbspec/carburetto ... s/id/1246/
Vegard
Norway
Post by Vegard » Fri Apr 15, 2016 10:30 am
Looks like a 27.
mylesw
Post by mylesw » Fri Apr 15, 2016 11:34 am
The dished washer goes on the slow running valve #15 in the picture. Spring probably also.
On my car the vacuum offtake for the distributor is on the front carb - you have it on the rear.
Myles
1964 RHD 3.8 FHC
Post by christopher storey » Fri Apr 15, 2016 12:00 pm
I agree that they appear to be part of the slow running valve. The large screw should have the spring put on it, and the assembly is then completed by the spring seat ( the metal part you have ringed ) and a conical o ring which holds the lot together
Post by mgcjag » Fri Apr 15, 2016 12:53 pm
I think they are from the spindle seal kit.....look at item no 27 and click to view....
Post by christopher storey » Fri Apr 15, 2016 1:54 pm
Steve : I've just looked again using the View button on the numbered list, and I agree they look more like 27 than 15 . But where are the volume screw bits ?
Edit : or are they two of the bits in the lower left half of the photo, together with the longer spring in the middle ?
Post by mgcjag » Fri Apr 15, 2016 2:14 pm
Probably the best way to tell whats what is to look up what the part no of the kit is you ordered and list its contents....then check with the Burlan site, and make sure what fits where and which way around those dish shaped washers fit.....
KingRichard
Netherlands
#9
Post by KingRichard » Fri Apr 15, 2016 3:07 pm
Correct IMO. Are part of the spindle seal kit with cork seals, WZX 994. I would advice the newer rubber seals though i frunning on modern fuel with ethanol.
It is definitely not from a part from the slow running valve.
richard
Vegard wrote:Looks like a 27.
E-type series 2 2+2 RHD 1969
Post by abowie » Fri Apr 15, 2016 10:28 pm
mgcjag wrote:I think they are from the spindle seal kit.....look at item no 27 and click to view....
I agree.
Vegard
Norway
#11 Re: Triple HD8 rebuild
Post by Vegard » Thu Dec 01, 2016 11:07 pm
I just noticed that one dashpot piston was longer than the two others. The result is that the dashpot won't rise fully.
Are there several types?
JagWaugh
Switzerland
#12 Re: Triple HD8 rebuild
Post by JagWaugh » Thu Dec 01, 2016 11:29 pm
Vegard wrote:I just noticed that one dashpot piston was longer than the two others. The result is that the dashpot won't rise fully.
Burlen calls out different numbers for the 420 and the E
For the 420 HD8s, the damper is AUC 8110
For the E HD8s, the damper is AUC 8115
IIRC the 420 and the E have the same venting with respect to the damper cap, but I'm not certain.
#13 Re: Triple HD8 rebuild
Post by PeterCrespin » Fri Dec 02, 2016 1:57 am
The 420 and MkX dashpot necks are taller, hence the longer damper rods. The springs and some other parts are different too.
Petr
KingRichard
Netherlands
#14 Re: Triple HD8 rebuild
Post by KingRichard » Mon Dec 05, 2016 6:22 pm
Hi, Definitely spindle shaft seals. Use the rubber ones not the cork.
