i took the clutch cover off this evening
flywheel is original, with the same numbering as shown on the cylinder head, and with a discoloured and slightly pitted surface to both it and the pressure plate (i hope i have that name correct)
the friction plate doesn't look particularly worn, with around 4/5mm thickness on each of the two disc rings, and having MADE in SPAIN on its pale blue coloured surface is not original I am guessing....not sure whether this is the original cover assembly, as the friction plate measures just under 10 inches in diameter
is this a better design than the original 9 inch design and should I revert back to 9 inches....and is it acceptable to have the flywheel and pressure plate surface skimmed to be perfectly flat and clean
thanks all
Jonathan
