sudden engine stall when rolling on speed bumps
rolando38
#1 sudden engine stall when rolling on speed bumps
Post by rolando38 » Sun May 22, 2016 8:48 pm
Hello
I recently experienced an unusual sudden blackout when going over a speed bump
by blackout I mean that the engine immediatley stalled -not pleasant with an auto box- and when trying to start again the starter woud not go
after shaking the cables going from the battery to the starter I was able to start again a few minutes latern, but again same thing happened a few miles later ; then did 200 miles without prblem
any idea where I should start my investigations ?
thanks
2+2 1970
Post by mgcjag » Sun May 22, 2016 9:33 pm
Hi Ronaldo...start with the cable connections that you had to shake to get it going again
Post by abowie » Sun May 22, 2016 10:10 pm
mgcjag wrote:Hi Ronaldo...start with the cable connections that you had to shake to get it going again
And the main engine earth cable that goes from the left side of the reaction tie plate to the rear left of the engine block.
rolando38
Post by rolando38 » Mon May 23, 2016 5:13 am
thanks Steve and Andrew; will investigate those cables and connections more in depth
there's no "inertia switch" or the like in theE-type ? (on my Stag I had an inertia switch that would shut down everything in case of shock but was defective)
2+2 1970
iani
Post by iani » Mon May 23, 2016 6:38 am
No, there's no inertia switch unless someone has fitted one.
E-type - TBC
1968 Triumph GT6 Mk1
andrewh
Post by andrewh » Mon May 23, 2016 9:38 am
I had this on another make of car and it was the main ignition feed from the switch to a bullet connector. A real pita to find, but likely to be just one connection at fault.
1962 3.8 Series One FHC
