I got replacement torsion bar shields and a LH mudshield as mine were all missing. From the parts catalogue there are meant to be rubber strips along one side of each of them. I have the rubber, I just can't see how to attach it to the shields. The wheel arch rubbers are riveted with the strips, but these I can't work out.
Any pictures anyone or guide?
Also, the handbrake lever aperture seal BD20469. It goes on the underside of the console, but no obvious way of attaching. simply glued?
rubber on torsion bar shields and LH mudshield and handbrake aperture!
#1 rubber on torsion bar shields and LH mudshield and handbrake aperture!
-Mark
#2 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
I thought I was the only person in the world with torsion bar shields!
From memory and paleontological examination of my original shields there was a strip of what actually looked like braided cotton military harness webbing maybe 2" wide that goes between the shield and the engine frame it's fixed to. I think the idea was to stop it rattling.
I never fitted any replacement. The shields rattle annoyingly.
#3 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
WRT the handbrake rubber; yes it is glued on. It will therefore fall off later.
#4 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Hi Mark.....I have the shields on my S2 2+2 and as Andrew says there was a webbing type material fitted.....mine are back on the car but no rubber fitted
#5 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Mark,
it wasn't rubber, it's a woven/braided textil band. I believe mine to still be original (but dirty) at least they are there. Doing stuff on the front end I took my shields off and cleaned them, I think the bands were glued to the shields bur are also held somewhat by the brackets as well. See in the pic upper right corner. My shields were bent, I straightened them out before reassembly, the pic is before work done.
Martin
Martin
Martin Scherz
Late S2 1970 OTS US LHD
#6 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Mark,
I found another picture of the original band. A bit dark, look closely. The bottom textil band is what I sourced as a substitute for one side.
Martin
Martin
Martin Scherz
