Top Gear E type
Topic author - Moderator
#1 Top Gear E type
Hi All.....just watched top gear on BBC 2 they recreated the Geneva run in an F type......worth watching and Norman Dewis was on repeated tomorrom bbc2 11.15pm
#2 Re: Top Gear E type
Hi Steve,
Yes I watch it. Although I find it hard to believe he arrived with seconds to go in a perfectly clean car. It helps watching top gear without hating the presenter. Clerkson use to really annoy me.
Tony (E typed)
Tony
Tony
mystery type
#3 Re: Top Gear E type
well I enjoyed the jaguar piece, was great to see Norman looking so well given that's he`s nearly 96.
might even tune in next week...
Paul 1967 S1 2+2
#4 Re: Top Gear E type
Did Norman have a quiet word with Eddie Jordan about his V8 S2?!!
Nickleback
#5 Re: Top Gear E type
Watch ExtraGear episode 5 for a lot more on 77RW doing a lap of the Dunfold track with Rory Reid & Norman Dewis OBE.
Lovely gear changes from the moss box !
http://www.bbc.co.uk/iplayer/episode/p0 ... -episode-5
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
mystery type
#6 Re: Top Gear E type
Another E type in the final episode of top gear.
Paul 1967 S1 2+2
#7 Re: Top Gear E type
And a chaved up MGB....naff does not come close...I have a genuine original MGB and Evans is wrong in everything he said. No leaks. Heater works, reliable...at least Eagle and Aston rebuild to perfection the existing engine. All the Abingdon idiots do is drop a modern engine in with more power. Ken Costello did that 40 years ago with the V8 which was so good MG did the same....only Evans failed to even mention that.
