Hi All,
I have a Series 2 2+2 and about to try and fit front and rear screen upper and lower chrome strips. I bought them all fom SNG Barrett. Do I soften the rubbers up or use any form of lubricant? I am told it can be difficult to get the chrome strips into the grooves in the rubber. Any tips would be helpful. Many thanks.
Chrome strips front and rear windscreens
Bernie2015
Topic author - Posts: 285
#2 Re: Chrome strips front and rear windscreens
Hi Bernie, it was quite hard for me to fit rubbers and chrome as you are going to. I used those "press " which are very usefull:
Before , i bent the chrome enough so they matched with the screen curve
If you want more détails: http://forums.motorlegend.com/vb/showth ... 59&page=12
Good luck !
Good luck !
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
Bernie2015
#3 Re: Chrome strips front and rear windscreens
Thank you for the information. Did you use any adhesive? Where did you find the presses? Many thanks
Bernie 1966 S1 OTS
#4 Re: Chrome strips front and rear windscreens
Hello Bernie, i used an black screen adhesive for the all the chrome , only a very light line along the profile which is pressed with the presses ... !
I bought the presses at : SM distribution : http://www.lacentraledupro.com/conditio ... _vente.htm
You can buy those in a other society i think .
Bernie2015
#5 Re: Chrome strips front and rear windscreens
Thats great thanks for your help with this
Bernie 1966 S1 OTS
