Running temperature?
#1 Running temperature?
Just wondering what the correct running temperature should be, I'm running 140F which i think is low? Checked the knowledge base but cant find an answer in there.
Thanks.
Thanks.
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
#2 Re: Running temperature?
Mine runs at between 75C and 80C.
#3 Re: Running temperature?
Thank you, looks like i need to check the thermostat.
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
#4 Re: Running temperature?
Or check the gauge
#5 Re: Running temperature?
Generally anywhere around the M A L of NORMAL I find. My brow only starts to furrow if the needle edges past the L.
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
#6 Re: Running temperature?
Mine sits towards the right hand edge of the LH white section of the gauge and only goes into the normal if stuck in traffic before the fans switch on, then kept there until on the way again and goes back to as before. Don't know how many degress C or F that is.
#7 Re: Running temperature?
mine sits on the "O" of normal as a maximum. Never goes higher. Sometimes runs cooler according to conditions.
#8 Re: Running temperature?
I guess the thing with the S2 gauge, as it doesn't purport to tell you actual temperature, is just to get to know what's normal for your car and be alert to it exceeding that.
Have to say I'm impressed with the S2's cooling. If you have any amount of forward motion that big mouth sucks in the air and keeps things in check: it's really only ever when stationary in traffic that the fans get called upon to provide a boost.
#9 Re: Running temperature?
Mine's exactly the same as this. The fans kick in when the needle hits the mid point. It's probably reading a bit low but I fitted a new sender so I guess it's OK. But as you say, once you're used to what's "normal" then you'll know if it's hot or cold.Gfhug wrote:Mine sits towards the right hand edge of the LH white section of the gauge and only goes into the normal if stuck in traffic before the fans switch on, then kept there until on the way again and goes back to as before. Don't know how many degress C or F that is.
Chris
1970 S2 Coupe
1970 S2 Coupe
Nickleback
#10 Re: Running temperature?
Yup, that's where mine sits too and the engine has only just been fully rebuilt.Simon P wrote:Generally anywhere around the M A L of NORMAL I find. My brow only starts to furrow if the needle edges past the L.
It's all about the temp sensor (highly variable) and the guage acuracy as to how it balances out, the important thing is when & at what temp the fans kick in !
Make sure the coolant is fully topped up otherwise the otter switch / fans will not kick in to cool it.
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
Stephanie Plum
#12 Re: Running temperature?
Your fans kick you in the r?
#13 Re: Running temperature?
Stephanie Plum
