S2 tacho, rebuild to electronic tacho
Quattrofrank
Norway
#1 S2 tacho, rebuild to electronic tacho
Post by Quattrofrank » Wed Jul 27, 2016 7:02 am
Is there anyone providing a rebuild/conversion of a s2 tacho to an electronic tacho suitable to EFI with tacho output?
At the same time it would have been great to get the redline from 5-6000 to 6-7000 or even 7500 if that is possible?
Best regards Frank
#2 Re: S2 tacho, rebuild to electronic tacho
Post by Gfhug » Wed Jul 27, 2016 7:23 am
Frank, this fellow does conversions of the tacho from RVI to RVC and takes the impulse from the coil (he did mine).
https://www.spiyda.com/magento/index.ph ... board.html
Not sure about how you would change the face or redline, except MLBS3V12 has reworked his gauge faces here, whether you could do the same?
http://www.myetype.co.uk/forum/viewtopic.php?f=3&t=9039
Quattrofrank
Norway
#3 Re: S2 tacho, rebuild to electronic tacho
Post by Quattrofrank » Wed Jul 27, 2016 7:48 am
Hello and thanks for reply :bigrin:
I dont think the conversion will work since I will use a 3 coil setup and have a tacho output from the ecu giving 3 pulses / rev
With regards to the updating of the face to include new redline, I guess that is a perfect solution given that the tacho will be showing correct rpm afterwards. Thats wy it would be nice to have an expert rebuilding the tacho and calibrating it.
I have of course the option to buy a brand new modern tacho, but I would like to have the original style tacho
#4 Re: S2 tacho, rebuild to electronic tacho
Post by Gfhug » Wed Jul 27, 2016 10:38 am
Frank, is it worth contacting Spiyda and asking what they could do for your system? They may have a solution?
ralphr1780
#5 Re: S2 tacho, rebuild to electronic tacho
Post by ralphr1780 » Wed Jul 27, 2016 1:59 pm
Frank, do you mean something like this?
http://trigger-wheels.com/store/content ... /p129.html
Ralph
'69 OTS + '62 OTS - Belgium
Quattrofrank
Norway
#6 Re: S2 tacho, rebuild to electronic tacho
Post by Quattrofrank » Thu Jul 28, 2016 5:36 am
Thats excatly what I need, thank you :)
#7 Re: S2 tacho, rebuild to electronic tacho
Post by PeterCrespin » Fri Aug 05, 2016 10:29 pm
Quattrofrank wrote: I dont think the conversion will work since I will use a 3 coil setup and have a tacho output from the ecu giving 3 pulses / rev
Every XK engine uses 3 pulses per rev - it's a six cylinder four-stroke... :oops:
