Hi Folks,
When the ignition is on and the handbrake is on, the light is on as it should be. However, when I switch the ignition off, the light is still glowing slightly.
I have established that there is a round 3V going to it, but I can't figure out why. And why only 3v?
I figured that the problem must be related to a circuit that is live when the ignition is off, which I think means lights or hazard flashers.
The other thing I have noticed is that the 5 way connector block from the indicator switch is 'warm'. So I am wondering if there could be some current leakage through the indicator switch?
I am near the end (I think) of a full restoration. The car has a new loom, new switches Including handbrake switch. I have replaced the 3AW really with an electronic alternative as the ignition warning light was not working. The ignition light now works, though it seems rather dim also.
All the other electrics work correctly, though I haven't fitted the bonnet yet so can't say for sure that the front lights work.
Any ideas?
Brian
