Post
by JagWaugh » Sun Oct 02, 2016 8:51 pm
Mark,
Start by trying to dissolve or pick the glie out first.
Greenfield, Butterworth were the names, but I'm not sure if they are still making their own stuff or if the small ones are made under license (special cat hair and snot alloy). If you are at a show like Fribourg, or Morges (Which was this weekend) here are some rules of thumb for spotting a decent tap set:
The only black part will be the square bit of the drive end. Everything else will be ground.
4 straight flutes
3 taps in each size (2x ground pointed end, 1x flat end) these will be marked with 1, 2 or 3 rings on the shank
crisp laser markings of the size and pitch and Mfr name. Even better if the alloy is also marked.
With Al, similar to the red metals, you don't want a brand new perfectly sharp tap.
For the moment if I were in your place I would look for a local classic car garage and stop by there at lunch. They will probably have inch taps (the grubscrews are #8 or 10 NF, but NOT Whitworth!), and the guy will probably clean the glue out for you if you put 10 or 20 CHF in the Kaffeekasse.
Starting a tap in a hole that is already threaded, particularly in a soft material, and a small NF hole at that is about the steepest part of the learning curve.
Ask him where you can get good taps and dies locally, or wait until the next car show and look there, or order from the UK.
Actually, you don't need a Tap and Die set unless you are making parts from scratch. What you really want is called a thread chaser set. These are sort of like taps and dies, but they are only designed to clean an existing thread of rust, dirt, loctite, paint etc. These are not widely known in the German speaking world. Unfortunately the smallest size of chaser I have ever seen is 1/4, below which you end up using a tap or die again. I use cheap blackened metal import taps for chasing really small holes - these are too crap for tapping a hole from scratch in anything other than cheese, but they're not bad for chasing a hole.
So... after all that - go into Migros, Jumbo, Obi or Coop, sometimes they have metric sets which include the small imperial sizes, but you have to look carefully to make sure that it includes the sizes you need.
