Car Security
Nickleback
#41 Re: Car Security
Post by Nickleback » Sun Oct 30, 2016 11:14 am
nottsman wrote:I've recently bought one of these http://www.back2you.com/self-contained- ... acker.html from eBay for a reduced price. Inserted SIM and followed instructions. Very easy and works a treat.
Well, the recent spate of thefts has made my mind up and one of the improvements that I have gone for is this:
http://www.back2you.com/compact-gps-veh ... acker.html
I have gone for the standard version with the cut off box all covertly fitted, should be done next week :hammerdrill: so will give some feedback ASAP
Mike,
1970 S2 FHC 2R28165
Turnip
#42 Re: Car Security
Post by Turnip » Sun Oct 30, 2016 8:35 pm
Another tracker to consider is this one: http://www.trackersecurity.co.uk/buy.html
It's monitored, so more expensive than others. The re-chargeable version and replacement battery version last 18months/2 years between charges, so they're not a battery drain for cars in storage.
It also has a vibration sensor, so you'll get a text or a phone call if the car gets a bit of a nudge, rather than waiting for it to actually move its location.
1965 Series 1 4.2 FHC
johnben
#43 Re: Car Security
Post by johnben » Wed Nov 02, 2016 6:43 am
Hi Folks
Thanks for the replies, I think this self contained unit will suit me best http://www.back2you.com/self-contained- ... acker.html though I just need to do a bit more research on it.
Re the removable steering wheel, I know I have a simplistic view of things but if I remove the central locking nut retaining the steering wheel and put the horn assembly back, don't I have a removable steering wheel?
I am retiring to the bunker to avoid the flak.
#44 Re: Car Security
Post by mgcjag » Wed Nov 02, 2016 8:53 am
Yes...but you have to get your spanners out.......removable steeringwheel set ups are just pull off/push on
johnben
#45 Re: Car Security
Post by johnben » Wed Nov 02, 2016 10:23 am
Sorry, I did not make myself clear, the retaining nut is permanently off, the wheel would stay in place in normal use due to the friction of the splines and gravity.
#46 Re: Car Security
Post by Heuer » Wed Nov 02, 2016 11:33 am
:thumbdown: :banghead:
Jaguar put a Palnut on because they were worried the main nut would come loose. Obviously should not have bothered!
BRM
#47 Re: Car Security
Post by BRM » Wed Nov 02, 2016 11:44 am
But removable steering wheels do not work like that. They have a quick release mechanism but when in place they are locked on - they do not just slide off.
There is a reason for the standard wheel having a big nut to hold it on - friction and gravity aren't sufficiently reliable and anyway after you've removed it a few times there won't be much friction left.
I don't think I'd want to be fumbling around trying to push it back on the splines as I'm hurtling round a bend at 70mph !
Brian
1969 S2 FHC 1R20267
1960 Austin Healey 3000
#48 Re: Car Security
Post by mgcjag » Wed Nov 02, 2016 1:24 pm
I assume you have the spinners on your road wheels :bigrin:.....i supose we should be saying quick release steering
#49 Re: Car Security
Post by PeterCrespin » Wed Nov 02, 2016 2:28 pm
johnben wrote:... the retaining nut is permanently off, the wheel would stay in place in normal use due to the friction of the splines and gravity.
John, you need to correct the 'missing a' typo in your ID.
"The name's Bean, Mr Bean" :smile:
Don't lose your split collets.
Red Kite
#50 Re: Car Security
Post by Red Kite » Sun Feb 05, 2017 2:15 pm
cactusman wrote:As requested, this is what I have
http://rbs-propertymarking.co.uk/gps_tracker_50.html
The listing seems to have disappeared from their website, does it have another name/brand name ?
Gerry.
S2 FHC 1R20003
cactusman
#51 Re: Car Security
Post by cactusman » Sun Feb 05, 2017 6:14 pm
it seems RBS no longer sell the tracker. However the one they sold is readily available from many other internet outlets including Amazon. For example...
Note that you need to buy both the tracker and the in vehicle charger and you will also need a SIM. RBS sold the tracker, the in vehicle charger, a second battery and a mains power charger plus an O2 SIM for around £120. Note that in their instructions most SIM cards will work but specifically NOT those for the 3 network.
johnben
#52 Re: Car Security
Post by johnben » Wed Feb 08, 2017 7:45 pm
I made some enquiries a couple of months ago and the unit was no longer available so I went for the Back2You unit which I am quite happy with. http://www.back2you.com/?gclid=CjwKEAiA ... oC6Zvw_wcB
John Series 1 2 + 2
mystery type
#53 Re: Car Security
Post by mystery type » Sun Apr 09, 2017 1:38 pm
This seems an inexpensive option, only £24.00, up to 1 year battery life, and no monthly costs.
Anyone tried this?
http://techiefans.com/is-your-own-car-o ... 0132md6428
Paul 1967 S1 2+2
#54 Re: Car Security
Post by Heuer » Sun Apr 09, 2017 1:43 pm
Interesting device - wonder if it works in the UK?
mystery type
#55 Re: Car Security
Post by mystery type » Sun Apr 09, 2017 2:05 pm
Says world wide...
Devices with iOS 8 & up
Android 4.4 & Later with Bluetooth Low Energy
Works World Wide
Paul 1967 S1 2+2
#56 Re: Car Security
Post by Heuer » Sun Apr 09, 2017 3:37 pm
#57 Re: Car Security
Post by mgcjag » Sun Apr 09, 2017 4:07 pm
Sounds like it works on crowd GPS.....with a range of 100ft.....so the trackr will ping a phone that has the app if its within 100ft....this nearest app/phone notifies the network of the location...then your phone gets to know.....sounds a great device, but relies on lots useing the app
cactusman
#58 Re: Car Security
Post by cactusman » Sun Apr 09, 2017 5:14 pm
Think you are right Steve. Ok in a street but not much good if your car is stashed in a dusty barn in some remote county location I suspect...
