Refitting headlights to bonnet
I have fitted the chrome trim which secures the lamp to the bowl
My question is should I now be fitting a further chrome trim over this and if so how are they secured
I do have two which came with the car in a box of parts
If they are to be fitted then how are they secured on as also I will need to refit bonnet first and set up headlights before fitting as the trim would cower the adjusting screws
Probably a simple one but search didn't show any pics
Any pics of help please
Headlight trim series1 2+2 covered headlight
#2 Re: Headlight trim series1 2+2 covered headlight
Hi Phil...the SNG site is very good for diagrams....have a look at this it may help .http://www.sngbarratt.com/CatalogueProd ... 48&a=15858
#3 Re: Headlight trim series1 2+2 covered headlight
If you have covered headlights the wide chrome finisher trim is not fitted.
If you have open headlights (S1 1/2 onwards) the trim is just a firm push fit. There is probably a little locating tab on the bowl. There may be a single screw hole in the trim to secure it. It's been a while since I did this on an open headlight E Type so my recollections are a little vague.
#4 Re: Headlight trim series1 2+2 covered headlight
Hi guys
Pretty clear what's needed now
Thanks again
Thanks again
