Ignition warning light wiring from pressure switch
#1 Ignition warning light wiring from pressure switch
Series 1 2+2
I am rebuilding the car and have installed a new auto sparks loom
All wiring is sorted with exception of the pressure switch wire (brown and black) which isn't in the loom. Which should go to the back of the ignition lamp
The lamp on the tachometer has the White from the fuse and brown and black to the the 3ra
Should I just wire the switch and join it to the brown and black feeding the lamp
I assume the switch is still needed (Car has a voltmeter) for the correct operation
Any suggestions or help please
#2 Re: Ignition warning light wiring from pressure switch
The warning lamp has a white wire to one side (positive from ign) and should have two brown/black wires connected to the other side of the lamp. One goes to the oil pressure switch. The other goes to the WL terminal on the 3AW warning light relay.
#3 Re: Ignition warning light wiring from pressure switch
hi Julian
Thanks and following the drawings your response is correct and how I agree it should be
However I only have a single brown and black wire coming from the light which I have connected to the 3aw and can't see anywhere the wire which goes to the switch
Have also just checked the old loom and it only has a single brown and black wire and no piggy back connector
Looks like I will need to add a separate wire, and connect to the brown and black
Would this be correct thing to do
#4 Re: Ignition warning light wiring from pressure switch
I would say yes....run a second wire from the lamp (or WL terminal) to the pressure switch. I know autosparks complete kits come with a pack of "loose wires". Maybe there is a brown/black wire there.
#5 Re: Ignition warning light wiring from pressure switch
Have the wire pack but no wire
Will run a separate single wire, down to switch
What size and rAting should it be..?
#6 Re: Ignition warning light wiring from pressure switch
Only switching the warning lamp so 5 amp rating would be fine.
#7 Re: Ignition warning light wiring from pressure switch
Hello,
I have installed the new wiring loom from auto sparks.
No I have the ignition warning light with a white and a brown/black wire not working.
On the wiring diagram it says the brown/black is coming from a switch.This switch also connects to a black and a brown/yellow cable coming from the alternator.
Now it happens that I found all these 3 cables between the battery and the regulator.
But where is the switch? I can not remember I have seen a switch there nor can I imagine how it looks and where to place it. I am talking about my S1 2+2
Many thanks for help again.
Maikel
Maikel
#8 Re: Ignition warning light wiring from pressure switch
It's not a switch, it's the 3AW warning light unit which is located near the alternator regulator unit.
1969 Series 2 FHC
1969 Series 2 FHC
#9 Re: Ignition warning light wiring from pressure switch
Thanks John,
how does it look and where it is mounted?
I can not even find it in the spare parts book.
Maikel
Maikel
#10 Re: Ignition warning light wiring from pressure switch
Found this in a box but unaware of the purpose.
it has a suitable date code, as my car is 1/67 But it came in a box with the car.
#11 Re: Ignition warning light wiring from pressure switch
#12 Re: Ignition warning light wiring from pressure switch
Just trial fitted the part and works fine.
The location could do the job, but I never actually noticed this unit.
Will go through some books and double-check,
But I sorted my open issue very quick.
Thanks a lot guys, have a nice weekend
Maikel
Maikel
