So the throttle linkage bushing closest to the bulkhead on my '66 S1 FHC is shot. Initially, I thought this would be a quick and easy repair, but the deeper I got it became apparent that it is far from it. After googling and watching some videos (thanks davejaguar66) I decided to bite the bullet and remove the entire intake manifold/carb setup. After spending the good part of a day removing the 18 manifold bolts, 3 of which were close to impossible, the heater hoses and disconnecting the linkages I was finally ready to remove the entire intake structure. Well, not so fast! It will not budge. even with penetrating fluid and light pressure from a crowbar between the forward part of the manifold and head. After a second day simply trying to remove the stuck manifold I am out of ideas. I replaced the exhaust exhaust system with a SS setup including headers and the exhaust side came off easily. I thought the intake side would also then, but no luck, it must have been replaced with some kind of adhesive. The engine was rebuilt in 1990, but has seen little use since. Does anyone have any tips for removing a stuck intake manifold?
Pics are the throttle linkage bushing and intake manifold.
davejaguar66 throttle linkage video:
