Sheared otter switch bolt
#1 Sheared otter switch bolt
While replacing the otter switch I've sheared one of the bolts off in the threads of the housing. I've ordered a new housing but can't source any new bolts. Barrett's and Manners' both say they are unavailable.
Does anyone know what size/thread they are or know where I could get hold of 3 new ones?
Also I've tried to attach a photo but the file is too large, how do I get over this problem
'72 S3 2+2 Regency Red
#2 Re: Sheared otter switch bolt
I'm not sure about the SIII, but on the earlier cars they are #10 NC (i.e. 10-24) Should be fairly easy to source those.
#3 Re: Sheared otter switch bolt
Common problem; they weld themselves in there. #10 or 3/16" UNC (NOT UNF). You might satruggle to find hex headed bolts but if you can't you could just use Phillips.
#4 Re: Sheared otter switch bolt
1971 Series 3 FHC 2+2 RHD Manual
1971 Series 3 Roadster 2+2 RHD Manual
1986 Rover SD1 Vitesse Twin Plenum
#5 Re: Sheared otter switch bolt
Thanks for the info. Now have fitted a new housing, otter switch and bolts.
Run up to temperature and the fans came on and no leaks
#6 Re: Sheared otter switch bolt
http://s38.photobucket.com/user/simon_e ... sort=3&o=4
This is a pic of my car (hopefully, if I've sorted photobucket)
#7 Re: Sheared otter switch bolt
Nice car Simon. Hope to have mine looking like yours.
Wes
Wes
1972 Jag E type coupe - Series 3
1968 Jag E type FHC - Series 1.5
#8 Re: Sheared otter switch bolt
Looking good. I too sheared one of those bolts and as mentioned drilled it and got in a stainless self tapper.
It's also nice to have a switch with light to activate the fan relay and thus switch them on manually in traffic.
Adam
1957 XK150 since 1976
#9 Re: Sheared otter switch bolt
Just for the sake of mentioning it, if the sheared fastener is ferrous, and the part isn't, you can dissolve the fastener.
https://forums.jag-lovers.com/t/xk-engi ... num/245409
#10 Re: Sheared otter switch bolt
Hi Guys
If you are looking to upgrade to more modern/reliable componentry, check this link to Coolcat out. I fitted one to my V12 several years ago; replacement senders are a modern readily available part from Porsche.
https://tinyurl.com/zpgjxoh
Mark Brown
