I have done a search on previous threads but opinion seems to be mixed ? So do you -
1.) What was the factory finish in 1970 on a S2, is it best to revert to this or
2.) Epoxy primer & powder coating or
3.) Epoxy primer, anti-rust paint (POR15), then Gloss or Satin black top coat or
4.) Red oxide, then Gloss or Satin black top coat or
5.) Should the diff case be painted differently, looks like a red oxide finish & the cage black like I have seen on some top end rebuilds.
6.) What items should be plated and with what finish.
& finally what parts should be always be changed out for new when doing this ?
Rebuild of the rear differential from XKE 3.54 to 3.07 UK specification using different Crown Wheel &
Pinion with existing carrier and LSD rebuilt.
Blasting and powder coating of components ?
Plating of all handbrake mechanisms ?
Full rebuild of hubs including new bearings & seals
Full rebuild of brake callipers with pads
New universal joints
New brake lines
What should be the mandatory upgrades whilst it is all apart ?
PS: I will not be doing the work myself but getting a specialist to complete, hopefully to the right specification as there are different options available.
