After my recent issue with removing some very stubborn (4 hours with a dremel and cutting disk) sealing rings from my exhaust I am finally ready to fit the new manifolds. I've been trying to set the studs into the manifold using the double nut technique. This has worked on some studs but not all as the standard nuts are quite thick and so it's hard to get two nuts onto a single stud without stripping the threads on the end nut when tightening.
Does anyone have any tools or techniques to fitting these? Also what is nut size as standard supplied by SNG Barratt as I was wondering if I could find some shorter nuts to give me room to get two properly onto the studs to double nut tighten.
Any help is much appreciated as usual. Here is how a couple of the more stubborn studs currently look, you can see they aren't fully located
Trev
