"If it aint broke dont fix it" (my aeronautical engineer grandfather used to say)
So, I think the best thing to do is ignore his advice and fiddle with it.
[/url]If you have followed my progress, I rebuilt a standard short stud thick deck 1967 engine and fitted it in January.
It has a free flowing exhaust and Jenvey throttle bodies with an Emerald ECU.
However, although it sounds great and goes well I think my engine has much more to offer.
On the rolling road, it put out 200 bhp at the flywheel and 341 nm max. I want more (please).
The compression test shows that with new Mahle 8:1 pistons the cylinders show 180,195,195,195,195,195 psi warm with the throttle open. I think this is good.
The oil pressure is off the scale at 70 psi running, 40 psi idling hot with a mechanical gauge. This is also good.
Oil consumption is small. Oil leaks are zero.
The head has no modifications. It is just all clean and new apart from the cams.
Valve clearances are spot on.
I have cams from a 420 saloon. They looked OK but I never measured them. Everything else is new having covered 1,500 miles or thereabouts.
I checked the cam timing at the weekend with the Jaguar tool and a dial gauge. It is spot on TDC.
I put some electronic verniers across a couple of lobes. The indicated about 9.1mm of lift maybe (they are not that accurate).
So I think I should spice it up with a nice new pair of camshafts now it is run in.
These ones look interesting.
http://www.pipercams.co.uk/pipercams/ww ... =JAG6BP270
Means I don't have to take the head off, just need to dial them in.
Looks like fun.
What do you think? Waste of time and money? or the road to bigger thrills.
Opinions please.
