Incorrect Fronont Lower Ball Joints
eddiecross
#1 Incorrect Fronont Lower Ball Joints
Post by eddiecross » Sun Jul 02, 2017 9:30 am
1969 S2 2+2.
Just fitted a pair of the sealed XJ40 lower ball joints. They bolted up fine to the stub axle but the taper in the lower wishbone is larger so need to come off again.
Did the taper size change with S2? Can I get any other sealed type ball joints to fit or do I need to buy the original type with shims?
Thx
Eddie Cross
67 FHC
#2 Re: Incorrect Fronont Lower Ball Joints
Post by mgcjag » Sun Jul 02, 2017 10:14 am
Hi Eddie....fitted them ok to my 69 S2 2+2.....did you knock the ring out to fit them....
eddiecross
#3 Re: Incorrect Fronont Lower Ball Joints
Post by eddiecross » Sun Jul 02, 2017 10:32 am
Hi Steve,
I did. All bolted up fine.
Got the Vernier gauge on the taper and slightly smaller dia on the XJ6/XJ12/XJS/XJ40 replacements. I'll check again but not hopeful. Part no. of the replacements is CAC9937. It does say Jaguar series 1 & 3.
Thx
Eddie
67 FHC
#4 Re: Incorrect Fronont Lower Ball Joints
Post by mgcjag » Sun Jul 02, 2017 10:38 am
Hi Eddie...did you get them from one of the usual suppliers or ebay.....might be a manufacturing problem...lot have fitted them ok.. Steve
#5 Re: Incorrect Fronont Lower Ball Joints
Post by christopher storey » Sun Jul 02, 2017 4:16 pm
I don't really understand this . Tapered joints by their very nature should go together solidly unless either the angle is wrong ( very unlikely ) or the difference in the taper diameter is a gross one. Where are you measuring the relative diameters? Incidentally I have fitted a number of the sealed XJ40 type and never had a problem , except that it is often necessary to shorten the fixing bolts
Hugo
#6 Re: Incorrect Fronont Lower Ball Joints
Post by Hugo » Sun Jul 02, 2017 4:34 pm
No idea what's going on here but it sounds pretty scary.
eddiecross
#7 Re: Incorrect Fronont Lower Ball Joints
Post by eddiecross » Sun Jul 02, 2017 6:10 pm
Good news....operator error. Slid the joint boots down- they were covering the full taper. All good
Thx
Eddie
67 FHC
Hugo
#8 Re: Incorrect Fronont Lower Ball Joints
Post by Hugo » Sun Jul 02, 2017 6:18 pm
Phew!
dal2.0litrefrogeye
#9 Re: Incorrect Fronont Lower Ball Joints
Post by dal2.0litrefrogeye » Mon Jul 03, 2017 1:06 pm
I like it when that happens it doesn't cost you any more and you can have a good ol laugh at yourself about it :drinkingcheers:
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
