Thanks for all your patience and help. I'm getting closer - probably. Mark the map switch itself is working fine but the map light does not light up while opening the doors.
So here are some new pictures and some more details.
In the center of this picture is the interiour light switch. One lilac green and the right pure lilac cable which goes out of the picture is the one which is not connected. My multimeter showed permanent +12V. The other one is
This one (center) is the map switch. A lilac white and black cable is connected:
I also found this bridge/hub/switch (don't know the correctl english word) where only one red brown cable is connected which does not make sense to me:
Thanks! Hopefully this brings more light into it.
Stefan
