christopher storey wrote:ETTony : it is not the vacuum advance which you need to worry about . It is the MECHANICAL advance mechanism which may be seized i.e. the bob weights attached to the central spindle . The first check you can make - without removing the distributor from the car - is to take hold of the distributor spindle and see that you can twist it against spring pressure , and that it springs back after you have done so. If it does not do this , then on the face of it the advance mechanism is seized. Even if it does spring back, you still need to check that it advances as the rpm rise, and you can only do this with a timing lightETTony wrote:
In the case I described in post #63, it was the vacuum advance that was causing the problem. The canister was "pulling", but the plate it was attached to was not returning to it's static position when the vacuum signal was removed. Further, it would stick at different advance positions. So, the static setting at the crank was a moving target. Removed, cleaned and lubed the bearing surface between the two plates and the problem was resolved.
