Throttle return spring fork 4.2 rear ?
Durango2k
#1 Throttle return spring fork 4.2 rear ?
Post by Durango2k » Sat Aug 05, 2017 8:39 pm
All,
I do have one "y" fork and one spring leftover.
I could not fit it to the rearmost carb. The frame was in the way.
How do I fit it ? I know the centre-and front ones look slightly different (mirrored ?)
For now, I have hung the spring to a different point, to keep the rear throttle disc closed.
Carsten
#2 Re: Throttle return spring fork 4.2 rear ?
Post by abowie » Sun Aug 06, 2017 2:12 am
The rear one is a triangular piece, different in shape from the other 2.
Durango2k
#3 Re: Throttle return spring fork 4.2 rear ?
Post by Durango2k » Sun Aug 06, 2017 6:44 am
I have seen that - will look for it. Did that change from 3.8 to 4.2 ? I have seen pics with 3 forks...
Carsten
