Here are pictures. It is 7.5 cm between the holes, and the hole-to-hole distance is wider then the fork I also found (but which is from a 3.8. when I look at the pics at SNG's for example):
So, I'll be investing 30 Euros (ouch) for a metal triangle.
Where does the larger triangle come from ? I thought maybe engine / ignition pointer, but no.
Maybe from an XJ6 engine ? I did slought one, maybe it mixed into my stuff ?
Carsten
