Alan, You can use a metric socket to move the clamp nut on the adjuster -- 17mm or perhaps 18mm, I forget. But you don't need Whitworth tools for that. [Answer to an old post, but...] The tension on one side or the other of the cams does not make any difference, despite the service manual statement. Where the tension is located depends on the location of the cams, and which way the lobes torque the cams in that position. Slack is "fungible", because if you turn the engine some little way the slack will transfer sides, or even move in to the center area where the adjuster sits. The service manual technique does not specify where the engine should be set and so cam position could be anywhere. What matters is that the chains not be dead tight. And that involves getting all the slack on either side of the cams out, but allowing a small amount of slack overall. My technique for that is to make the chains dead tight -- turning the engine and retensioning until all slack is gone, and you can't move the chains on either side -- then backing off 2-3 clicks, which gives you the slack you need. At that point after turning the engine once you should be able to move the chains on one side or the other with a long screwdriver. What you have done is reliably met the factory specification of "not dead tight". Worked for me for the last 40 years...christopher storey wrote:Don't be non-plussed. The tensioner operates on that length of chain which naturally lies between the sprockets . When it is turned it moves eccentrically downwards to increase the distance that the chain travels between the sprockets . Unless in so doing it moves a camshaft ( which ideally it should not do , it is only the tension in that part of the chain between the sprockets which is affected . I think it is a problem of nomenclature really : the adjuster does not really tension the chain - it would be more accurate to say that it takes the slack out of it. If your chains on the outer side below the sprockets are whip tight, which they certainly sound to be , then in some way the chain is over-tight. There should be a small degree of flexibility demonstrable by pushing inwards with a finger . At a rough guess I would say you should be able to see the chain move between1 and 2 mm and spring back again
Jerry
