Mystery Button
Grant
#1 Mystery Button
Post by Grant » Sun Oct 08, 2017 7:28 pm
Hi All Knowing Ones !
On my 1969 US OTS I have a small round button just above the hand brake warning light , does anyone know what it should do ?
When I press it I can hear a click like a relay clicking but nothing seems to happen .
I've looked it the operating handbook and they may be a horn button ? But it's difficult to see in the picture and my horn works on the end of the indicator stork.
It has 2 red wires coming from it but I've not traced them very far yet .
Any body else have one of these ?
Thank you for reading so far
Grant
Series 2 OTS LHD
mark10337
Switzerland
#2 Re: Mystery Button
Post by mark10337 » Mon Oct 09, 2017 10:46 am
It is definitely a non-standard item that a previous owner has fitted for some purpose. You would probably have to trace the wires to find where they connect to.
-Mark
Grant
#3 Re: Mystery Button
Post by Grant » Mon Oct 09, 2017 7:55 pm
Hi Mark
I'm guessing you are right by the lack of replies no ones seems to recognise it! As you say I will have to trace the wires .
Thanks for confirming it.
Grant
Series 2 OTS LHD
mark10337
Switzerland
#4 Re: Mystery Button
Post by mark10337 » Mon Oct 09, 2017 8:57 pm
You're welcome. The hole there is original as it is where the light for the rear window heater goes, but on the OTS this is obviously not fitted and a blank is fitted over the hole. This would be a good choice to reuse for some other function as the hole is already there, and it is common for it to be used for some upgrade or secondary control switch.
-Mark
