Water Tank
PAUL MORRIS
#1 Water Tank
Post by PAUL MORRIS » Mon May 03, 2010 9:07 pm
Dear Forum,
what should be the proper water level from a cold engine, whats best to
use, pure water or coolent etc.
Thks
http://cid-409d34c9142de6b9.skydrive.li ... ^_3668.jpg
1954Etype
#2 Re: Water Tank
Post by 1954Etype » Tue May 04, 2010 9:15 am
PAUL MORRIS wrote:Dear Forum,
Thks
Paul (assuming you addressed this to the forum :? ) use correctly mixed antifreeze. Fill the expansion tank to the brim. When you run the car, it will find its own level by expelling it through the top of the radiator. (You have to have room in the tank for the water to expand into).
PAUL MORRIS
#3 Water Level
Post by PAUL MORRIS » Tue May 04, 2010 9:59 am
Dear David,
Sorry I wanted to write to you, who could imagine another forum.
Do you mean I must fill the metal expansion bowl to the brim or the radiator itself.
Merci
Paul :D
1954Etype
#4 Re: Water Level
Post by 1954Etype » Tue May 04, 2010 10:15 am
PAUL MORRIS wrote:Dear David,
Merci
Paul :D
Paul, the only place to fill on your car should be via the tank on top of the radiator (the expansion tank). Fill this to the brim.
PAUL MORRIS
#5 water tank
Post by PAUL MORRIS » Tue May 04, 2010 11:40 am
Dear David,
Sorry to bother you,
Do you mean to the brim with the engine running or not.
Thks
1954Etype
#6 Re: water tank
Post by 1954Etype » Tue May 04, 2010 11:54 am
Thks
ok, here is what you do:
1. Engine should not be running
2. Remove cap from expansion tank (rectangular shaped tank on top of radiator) when engine cold.
3. Fill to overflowing or brim (doesn't matter as excess will be automatically ejected when engine is hot).
4. Replace cap.
5. Start engine and let idle (or drive it) until at operating temperature.
6. Switch off - at this point you will see the excess water being ejected via the small hose near the radiator cap.
That should be it. Run the car to make sure the temperature is correct.
PAUL MORRIS
Post by PAUL MORRIS » Tue May 04, 2010 12:01 pm
Dear David,
Thks for your super quick answer,
Are you part of ETYPE UK ?
Post by Heuer » Tue May 04, 2010 12:28 pm
It was not me who answered - it was another Forum member called Angus. No need to post questions to me directly as there are a lot of other folks here who know more about these cars than I do!
PAUL MORRIS
#9
Post by PAUL MORRIS » Tue May 04, 2010 2:31 pm
Dear David,
Ok well understood but it seems you sleep & eat with the Forum or in the
boot of your lovely car.
Post by Heuer » Tue May 04, 2010 2:46 pm
That's because I have to maintain and administer the Forum as well as answer the odd post.
