He needed help with his Land Rover doors which wont open or close.
The E lives on a CTEK trickle charger, it struck straight up and off we went, full tank of fuel.
No problems still goes like a rocket. Reminded me what its all about. Drives so effortlessly and is so comfortable.
No rattles shakes or vibrations. Perfect apart from a couple of niggles.
Just noticed the speedo (recently rebuilt) cannot keep pace with the acceleration. It hangs around bottom speeds on the dial at 30mph then flicks up to 80mph when I change gear. I suppose it must be the cable? anyone experienced this before? Its a bit like it is twisting up a spring that is then releasing?
The speedo cable, is about the only old "old" bit left" It is the original long LHD one. Maybe time for a new shorter one?
The other niggle I cannot solve is constant low speed brake noise. A regulat wheel spped gringing nooise.
It arrives after a couple of miles, like the rear pads are dragging on warped discs. All the pads, discs, lines calipers and everything are recent of course. Its quite annoyingly audible with the window open. It thought it
might just go away, but it hasn't yet. In all other respects the brakes are fine, nothing gets hot or anything.
