Headlights
TiltyV12
#1 Headlights
Post by TiltyV12 » Mon Feb 19, 2018 9:29 pm
Hi Guys ,
I am close to now getting my imported USA LHD series three on the road legally in the UK.
What do I need to do on the front headlights to comply with the MOT test here ?
Also if I need to change anything what is the best upgrade parts to fit Headlights ?
Many Thanks Brian Tilt.
Brian Tilt
USA import 1973 automatic series 3.
Whitact
#2 Re: Headlights
Post by Whitact » Tue Feb 20, 2018 8:44 am
Hi Brian,
I used these: https://www.carbuildersolutions.com/uk/ ... side-light
With the relay mod to the wiring and Nightbreaker bulbs. Much better than the standard set up and almost as good as a modern for night driving.
Cheers,
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
MarekH
#3 Re: Headlights
Post by MarekH » Tue Feb 20, 2018 10:42 am
Dear Brian,
You need headlights which dip to the right. There are plenty of options available as Minis and Land Rovers used the same lights. Replacement H4 style housings which use a digfferent bulb to the original sealed beams are also available.
For the indicators, you need to replace the all-red rear indicator lenses with ones which make your rear indicators to be amber instrread of red.
#4 Re: Headlights
Post by Series1 Stu » Tue Feb 20, 2018 3:52 pm
Isn't that dip to the left for RHD, Marek?
MarekH
#5 Re: Headlights
Post by MarekH » Tue Feb 20, 2018 4:04 pm
Yes, that's exactly right.
This may also expain why nuts seem to get tighter, no matter how much I undo them.
lowact
#6 Re: Headlights
Post by lowact » Wed Feb 21, 2018 8:20 am
In Aus there was also requirement for the parking lights to be white and front facing instead of the sidelights. I was buying a bunch of stuff from SNGB at the time so I added in the RHD lights with the integral parking lights, SNGB code QRB4698. This was a few years back. Then I got rid of the US sidelights for a much cleaner look.
For the rear blinkers I thought to wire in the US rear orange sidelights. In the end not, I discovered that red flashers are tolerated here. Happy about that, imo the UK design stoplights are a bit unobtrusive.
