Some time ago I noticed a posting on here about fitting series 2 rear calipers to a series 1.
I think this required some grinding mods to the caliper bodies. I now can’t find that post despite a good search. So if the original poster ( or indeed anyone) has this detail I would be interested.
Tim
Series 2 rear çalipers on a series 1
#1 Series 2 rear çalipers on a series 1
#2 Re: Series 2 rear çalipers on a series 1
Does this help Tim...viewtopic.php?f=3&t=3748
#3 Re: Series 2 rear çalipers on a series 1
I have Series 2 rear calipers on my Series 1 and, if I remember correctly, I needed to cut away some of the sheet metal on the cradle to give them some clearance. I then reformed the lips on the apertures to put some strength back into the cradle.
I'm sure that I didn't have to modify the calipers in any way.
#4 Re: Series 2 rear çalipers on a series 1
Here i am ..... ! i did that on my calipers :
The "yellow square " is the metal which has been grinded for clearance.
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
#5 Re: Series 2 rear çalipers on a series 1
Thanks for that, do you still need the horseshoe shaped brackets that secure the calipers to the diff ?or do the calipers bolt directly to the output shaft cases?
#6 Re: Series 2 rear çalipers on a series 1
Idin't need the horseshoe.
