Heuer wrote:Sounds like an air lock to me.
Hi Heuer, i was thinking that too, which is why I purchased a air bleed valve from Rob Beere racing. Sits in the engine temp sender. Still even with that open I have had a collapsed hose from the Rad to the header tank with no heat going through to the other side of the tank. Fixed that (air blockage)
Now have a rad which now does heat in all 4 corners. Drain tap on engine does have water coming through.
Engine runs fine until it hits 75-78+ temp. It does not seem to lack power it just i slow down because of the noise. Before I added all these nice extras she rarely hit 75+. The alloy rad does have a electric fan built on and it does come on at 70 deg.
Regards Captain Heuer
My current classic squadron incl: 1963 e-type 3.8fhc + 1990 XJR-s 6.0 + 1968 Radford Mini Cooper
